Ford fiesta st
Ford fiesta st with stop start engine turns over 3 times then cuts out will not start  ideas
That would be more of a Stop/Stop engine 🤣
Have you tested the battery with a multimeter to see what the voltage is ?
Yes its been in garage they dont know what the problem is tryed spare key as addvise but still the same don't know where to go from here
Is it an ST or an ST-Line?  I didn't think the Mk7 ST had stop start.  Unless you mean it's push button start?
You'll have to let us know what the garage have tried already.  Battery check?  Diagnostic check?  Is the immobiliser light flashing?
Yes push button start and the garage have said they have checked battery  and all codes have been rectified so no lights on
Ok, thanks for clarifying.
Indy garage scanners don't pick up Ford specific faults.  So really the best option now is to get Forscan on it if that's something you feel comfortable doing.  If not, taking it to a Ford dealer would probably be the only other option.
Ok thanks the only problem is there is a 6 week waiting list Ford have told me
Another member has been quoted a month or so as well.  Not sure what that says about Ford reliability. :rolleyes:
If you're fairly savvy with a phone/ or laptop, Forscan is pretty straightforward and only costs around £20 for the adapter.
Try asking another dealer. This is a long standing tactic by main dealers of all makes who just don’t want to do the work. Particularly if you are not a regular customer.
  • 4 weeks later...
Local garage found the problem is was a broken wire and one corrosion wire cost £300 but now back on the road
