Faulty codes p0130 and p2100
Hi. Wondering if anyone can help.
I recently changed air intake pipe. part number 2s61-9a673 but then two codes popped up afterwards. P0130 and p2100. Doesn’t anyone know what the likely cause is. If I fix one of the codes will it fix the other. Thank you.
also some times a warning like comes up and it limits the my speed.
The codes are for lambda sensor & throttle body.
Which engine is it?
Which pipe have you changed and why?
ford fiesta 1.25 zetec 2006
this is the one I removed because the old one kept coming out while I was driving
Ok, that pipe shouldn't cause those faults.
If you can clean and reset the throttle body that would be a good starting point.
Also check you haven't accidentally knocked any thin vacuum pipes around the manifold and TB.
The lambda fault could be caused by an intake fault, but it may also be coincidence and the sensor itself is failing.
I'd definitely start with the throttle body myself.
