Mk6 Rev Counter Over Read
My MK6.5 Fiesta is over reading on the rev counter. It has done for a while now and hopped you guys could help find the cause. I've attached a picture for reference.
I can reset the dash by removing the fuse and all work OK for a few days.
Any suggestions?
Have you tried using the 'Gauge Sweep' test to reset and calibrate the dials ?
Yep, done that but the needle still over reads until the fuse is removed.
Looks like you have a defective Rev counter.
Easiest way to fix it is to buy a secondhand instrument cluster (eBay ?) and then swap the rev counter over from the spare.
You can't swap the whole instrument cluster because it is part of the immobiliser.
Can't you just take the needle off and put it back on in the right place?
Cam position sensor is playing up. All sorted now.
