GO CO Genius2uk battery charger
Can I use this to charge my car battery which is a EFB 60Ah Varna battery, on a  ST 1000 Fiesta with a stop start system.
Yes if you connect it to the car correctly. Make sure the negative lead is connected to the chassis earth point and NOT the battery terminal.
I suspect you will probably be given at least a Yellow card by a member of this forum 😉
Assuming you mean NOCO Genius 2?
I have a Genius 5 which typically takes up to 8 hours to go through a full charging cycle.
According to the product information on the NOCO website the 2amp version could take over twice as long, but as long as you have the time, it should be fine.
I prefer the the "Einstein a Go-Go" charger it has a good beat 🤣
