Ford Fiesta MK8 Rear Camera Install
Well, I don't know the cheapest but I do know the best. You will need to spend about £85.  The standard camera is readily available used from about £60, sometimes less. A bit of wiring(which involves removing part of the dash and dealing with some fairly small and fiddly connections) and then finally using an ELM 327 dongle and Forscan to turn it on. That gives you all the functionality of the factory camera because that is what it is. It ends up being the simplest method as well.
