Ford Fiesta MK8 Retrofit Puma MK2 digital cluster
Hello,
I recently put a puma digital cluster in my Fiesta Zetec. The screen works fine apart from it won’t show the PSI/Bar of the tires in the ‘tyre pressure’ menu. It says ‘press to store’ and once you press it no values come up even after a drive.
Is there a way on forscan to code it in? When looking in the IPC there was an option called ‘Tpms pressure display card’ and this was disabled.
any idea what the place card is and whether it could be the display? If not any other advice will be appreciated
