12V PowerPoints and Fusebox
Hey
I’ve just purchased a 66 plate Fiesta and the 12V points aren’t working (both the one in the back and the one under the handbrake). I can’t seem to find any lists that don’t contradict each other so I was wondering if anyone could help me with pinpointing the fuses I need to replace or which ones are missing?
Many thanks
That picture should not be the fusebox for a '66' plate 2016 Fiesta.
See this link below for the correct handbook:
https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=4409&languageCode=en&countryCode=USA&Uid=G1805098&ProcUid=G1805099&userMarket=GBR&div=f&vFilteringEnabled=False&buildtype=web
The fuse for the cigar lighter socket (next to handbrake) and the rear power socket is Fuse F61 (20 Amp)
I’ve attached an image of the fusebox in my passenger compartment, it doesn’t appear to be the same as what it ‘should’ be 😕
It would seem that you have a 2014/2015 model Fiesta that has been very late registered.
This is the handbook for your model: https://www.fordservicecontent.com/Ford_Content/catalog/owner_guides/ENUSA_CG3582_FCN_og_201402.pdf
Fuse 30 (20 Amp)
Fantastic, thank you so much 😊 I’ll get hold of the right fuse tomorrow
