Vacum problems
My son has a 2015 fiesta 1 ltr eccoboost.
It has developed a fault with the vacum and brake pedal.
Engine is rough and foot pedal is solid any suggestions
The brake servo faulty maybe
On a 1.0 ECOboost it is more likely that the camshaft driven vacuum pump has failed.
The vacuum pump on these engines is well known to fail in 2 different ways:
1: The integrated plastic check valve is broken. The check valve is part of the pump and not available as a separate part from Ford. There are however aftermarket part available to fix this problem.
2: The vacuum pump developed mechanical damage and clogged the check valve with debris. This is an early sign of oil starvation caused by wetbelt particles blocking the oil pump inlet.
Thanks JW. That is worth knowing.
