2012 1.4D not cranking
Good Evening
wonder if anyone can shed any light on a no crank situation
we have changed battery and starter motor after the car developed a no start after being driven the day before
have checked most items but quite oddly the starter relay is operating via ignition
checked relay for continuity on switched pair but still no crank
it seems that the return path is not reaching the PCM
can anyone advise if there is a starter interlock in the circuit or any other item that we may have overlooked in this fault finding mission
appreciate any thoughts in advance
kind regards
Terry
7 hours ago, unofix said:
Good Morning Unofix
many thanks for your reply
as the starter relay is energised and the car will start with key in on position after jumping the relay output had dismissed the key as the problem but will get that checked
diagnostics reveal there are no codes present in any module
once key has been reviewed will post back with update
Many thanks & regards
