U0121
I'm getting a U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module 'A'
On both the PSCM and IPC
Where do I start - anyone else had this
What are you using to read the DTC's and get that code ?
Forscan
What happens if you try and clear the DTC ?
Just checking that we are talking about the Fiesta 2016
They return straight away and yes the 2016 ecoboost st-line
Checked the obvious fuses, reset the module, and even swapped out the module with another one all with still the codes remaining.
Have you checked the resistance of the canbus at the OBDII port ?
It should be 60 ohms if the circuit is complete
Not yet - is that an easy task to do, is there a guide or which pins - than you
This video might give some help with fault finding.
Cracking video
Where can I find those wiring diagrams and total wiring harness connection locations for my car
Also what was he using to run that network test
60 ohms at the OBD port and ABS module connector
