S-max water in boot
Hi I have a big problem with water in boot checked rear lights all dry when I was replacing door loom I noticed the connection to the passenger rear door Piller was wet where could this water be coming from the door seals look good
Is there water inside the door ?
Check the drain holes in the very bottom edge of the door to make sure they are not blocked.
Will do but it seems as if it coming from the roof
