MK8 Fiesta ST line rear brake/tail light issue
Hi all hope someone can help, my issue is my NS rear light not illuminating although brake light works fine, checked the double filament bulb and it was fine, swapped out the bulb for a new one with the same issue again, seen on here somewhere that the problem may be the bulb holder but for the life of me cannot find these parts anywhere online to swap them out, also no obvious fault in the holder ! and suggestions would be appreciated cheers.
Checked the fuse?
The rear lights are directly controlled by the Body Control Module (BCM). Is the front little parking light (sidelights) working on the nearside ?
Have you got a digital multimeter that you can check the connector ?
