2014 1.0 Ecoboom coolant leak
Wife's ecoboom has coolant leak. Found its a weep at the larger waterpump nozzle hose connection which goes down to the bottom of radiator. I can see the coolant residue tracking down the hose. As there is no room to get even a small mirror up to the hose clip area at the pump I'm not sure if the hose has a small break in it at the clip or it could be the common fault of the pump O seal failure? Anyone know the O seal failure leak point or had this hose fail in the past?
Well on a 2014 plate you may as well just get the wet cambelt changed now and at the same time the water pump replaced.
