Zetec s tdci power steering failure
Hi all
been having issues on my fiesta regarding powersteering warning light on the dash tried changing the pump and checked fuses and still not working
the car also has an abs light on so i got someone to check the codes and it said the car has no fault codes for abs or powersteering so i was wondering if this meant the ecu could be to blame
Need someone with Ford specific diagnostics to check.
Does the speedo work ok?  The ABS sensors are used as a speed input for the electro-hydraulic PAS.
