Mk6 1.4tdci fiesta issues
Evening All.
My cousin has a 2006 1.4tdci fiesta, which was running fine until a month or so ago. Engine management light came on and was running like a bag of *****. Plugged in ForScan and EGR Valve fault. Removed, cleaned and refitted, OK for a few miles and then same again, so new EGR valve fitted. Also changed Brake Booster vacuum pipe and it developeeld a hole from rubbing against wiring loom.
Now when driving it lacks turbo boost. Ticks over fine, but no power when driving.
No fault codes showing.
Any ideas?
As you've mentioned the brake booster pipe, I'd be looking at the wastegate vacuum pipe & solenoid.
Odd there aren't any codes though, have you tried Forscan or just a generic OBD?
