rear wiper problems
ive got a mk 4 fiesta, and the rear wiper doesnt work. when i try switch it on, theres nothing! no noises, no movement. what could it be?
Could be the motor, could be a fuse, could be the stalk itself.
O and welcome to the club
have you checked the fuse?
thanks.
where is the fuse?
how much would a motor cost?
Fuses are normally under the glove box and in the engine bay.
Best bet for a motor would ebay but depends if you want a new one or not.
ok thanks alot, will check it.
my fuse box is well confusing lol, and looks like theres loads missing!
Not all the fuses will need to be filled as some of them will not be on your car.
Should tell you what they are for on the cover of the fuse box or in the handbook
i found the problem! where the fuse goes has been melted :angry: does that effect the relay?
Sounds like the motor/washer pump if there is no noise then its prob going to be that, check the motor see if theres any power going through.
Well thats not good! If it's melted then i would imagine that would effect the relay yes
more to the point what caused it to melt in the first place?
dont have a clue, previous owner had a amp and sub in boot and some wiring goes through to the fuse box, might of been putting out to much power of something :blink:
I dont know why he had put the wires through the fuse box!!
i dont know anything about eletrical stuff, so dont know, can it fail its mot because the back wiper aint working?
Not entirely sure, they do check the wipers and i would imagine it may fail as they would class it as not being safe. Although some cars dont have a rear wiper so they may not include it in the test.
But its like a third brake light, it's not illegal if you havent got one but it is if you have one and its not working!
  • 1 month later...
hey mate i have same problem with myn wen i drive down the road myn comes on what it is is the metal connections on bootlid and on boot slam panel rub all the crap off that i cn normally get it to work after a while put the wiper power on and go and bounce the boot it should move n.
