Passenger seat belt
Where seat belt clips in, there is soft padding to stop it rubbing the centre consul, it's coming unstuck, am I best to double sided tape it, or glue it, also what glue would be best, I don't want to pull the hole pad off, as it might be tricky to insert as it is a tight fit at the bottom, thanks for any advise
1 hour ago, LostNTransit said:
Our seat belt did the same as yours, but we opted to remove the pad and replace it with the hook & loop Velcro (loop side) or the fuzee side cut to fit.
That's a good idea, I tried superglue a while ago, it comes unstuck, good for glueing fingers though.
Thanks for that, I bought 50mm heavy duty Velcro and fitted it, it's worked a treat.
order some VHB from china via Aliexpress its cheaper than buying here
