Ford a max 2007 dashboard ligths off white driving
Hello i need some help white my s max 2007, while driving the ligths os dashboard and front( Ac, esp....etc switch off, all except radio..... And after some time they come on again, i already changed ignition, its doing the same, did this hapaned to anyone on gere? Ii believe its is a Simple thing
Check for loose connection at the GEM/BCM, wherever that is, or the IP connections
Thump the dash above the instrument cluster and see if this returns display to normal. Worth a try but normally affects Focus of that age and Kuga mk1 if it’s the dry solder joint issue.
