Rear wiper
Hi everyone, my daughter has just passed her test and bought a mk6 fiesta, the rear wiper won’t turn off when I put a fuse in, I’ve got conflicting arguments wether it’s the switch or relay,, also I couldn’t find the relay, any ideas ?
tia
Could also be the GEM.
Check the condition of the switch first though
Don't think there's a separate relay on the Mk6.  Stalks don't often fail.  GEM would be my first point of call as well.
Excuse my ignorance, what is GEM ?
General Electric Module.
The electro-mechanical "brain" that controls many functions of the car.
I’m a Range Rover nut, mines a becm 🤣😂
any idea where this gem is hidden, I take it all numbers must match ?
It's called the body control module nowadays, I don't know where it is on MK6, they're normally under the glovebox though. It'll be the unit where all the fuses and relays are.
As a cheap fix, you could mount a switch on the dash, switching the fuse on and off to turn it off when you don't want it
Thanks Dave, sounds like an idea, she’s just passed her test so it’s only a old banger to gain some confidence from
One thing I always like to try when anything involves a"computer", is to carry out what is known as a "Ferranti/Marconi/Schlumberger/Windows Reset".
In other words, disconnect the battery for an hour.
But the fault might just be the "Park" contact in the motor itself.
12 hours ago, Paulkp said:
Marconi
There's a good old name from the past. I worked for Marconi for just over 10 years, 1978 to 1988 when sadly the factory closed.
A bit off topic, but Marconi.....
My first experience was the "Oceanspan", and final was the 7500 UHF Pulsed Klystron TV transmitter for the IBA.  Ever meet Tracey Pearl ?
