Ford Focus 18 plate Hazard light issue.
Hopefully someone can help.
Hazards come on and off through the switch without ignition on. With ignition on switch won't work,  aslo if hazards are on and then turning ignition on, hazards won't turn off. It appears that with the ignition on it seems to bypass the hazard switch.
Any ideas please.
Focus Mk3.5 or the Mk4 ?
Have you got a laptop with windows ?
Mk3 I do have a laptop top also
The best thing to do is download FORScan on your laptop and connect to the OBDII port with a vLinker FS cable.
You will be able to check for any Ford specific DTC's, which I don't think you will find, but more importantly you will be able to live monitor the operation of the Hazard switch.
The fault could be with the switch, but it could also be with the BCM (you want to hope not).
FORScan: https://forscan.org/download.html
vLinker FS cable (ONLY £28.88 today) : https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
vLinker FS cable (ONLY £28.88 today😞 https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
OK cheers
