Cruise control working from time to time. Galaxy 2011
20230427_181300.thumb.jpg.ebd4851b7f8f416a0e3c8d13cfee93f1.jpg20230427_181327.thumb.jpg.f3ca04dc641d495df10d8db129c94f4f.jpgHi,
Forscan shows p0833 clutch position sensor. Signal invalide
Replaced it with an original one. Replaced the brake light switch as well. Still nothing. It comes on but it does not kick in.
Works after delete of code. Until car is turned off again.
Any suggestions ?
Will the engine start with out depressing the clutch pedal ?
If yes then the clutch pedal switch needs adjusted as it is constantly telling the PCM that the pedal is depressed.
No. It has to be pressed with the brake as well. No issues with that..
