Dvr's side passenger door Red light
I have a red light on my dashboard indicating my drivers side passenger door is open but it is definitely closed. I would like to fix this! I
Is this an MOT failure matter?
oberks
It's not an MOT failure.
First thing to check is the wiring plug between the door & the car body.  If that's clean & dry (no sign of corrosion) then you'll probably need a new door latch module.
Try spraying some WD40 in the latch then opening and closing the door loads of times and see if it clears
That's worked for me in the past!
TomsFocus, thank you for your replay.  The biggest thing is it's due for an MOT next Friday so I am very pleased that it's not an MOT failure! I will check the plug tomorrow.
Thanks greatly
5 hours ago, Eric Bloodaxe said:
I have already sprayed WD40 on it but it didn't work.
Iv'e already tried that but unfortunately it didn't work
