Key synch
I have an old Fiesta 2006 model, the keys were stolen and I have re-programmed the replacement. That key opens and locks the doors but does not operate the ignition. The slave key with no buttons operates the ignition.
Also the boot has jammed closed, if I change the lock how do I re-programme the key
Any advice gratefully received
You need to have two keys that work and start the engine in order to be able to programme the immobiliser part of a new key.
If you have only one working key then you need the new keys programmed by Ford, an Auto Locksmith, or use FORScan and do it yourself.
