Head display screen
Can anyone help please, i tried to put a new head display screen in but when i pulled the 12 pin plug out the back ive pulled the wires out of tge plug, i havent got a clue where they all go if anyone can help me please
Oh bu99er and words like that !!!
Can you post some photos of the wires and the connector. I have quite a lot of wiring schematics but nothing for a 2008 Fiesta. However it might be the same or similar to other models.
This is the only 1 i have at the minute but all the wires ive tried pitting back in myself
Just checked the Kuga and Focus drawings of the same year but nothing to match your connector 🙁
No worrys thanks anyway
Brown green is pin 10 I think. I'm just checking to see what I can find. If you look closely there should be numbers on  end of connector.
Are the colours , black/blue ,orange, grey/yellow , next should be brown green.
Im not 100% but i can check later today, wasnt sure if anyone had a diagram for it
15 hours ago, WBoc85 said:
... but when i pulled the 12 pin plug out the back ive pulled the wires out of tge plug,..
You see, this is exactly why I do very little myself, I'm a born klutz and know whatever I tackle will end up in a proverbial SNAFU 😂
These are the colour of the wires i have, i checked and the numbers arent on the end of the wires
Like I said the numbers are on the connector . 1 , 6, and 7 are shown so you know which wire goes where in a fashion .
So what wires have you left to refit?
I did find a diagram for the connector earlier today but forgot to post it up. Will go look for it in a while.
None of the wires are in the right place i just put them all back in the plug so they dont touch, but i dont know what order they go into the plug
Here is what I've found. So from the connector you should now know what the pin numbers are from 1-6 and 7-10. And from this diagram you know what the colours wires should be and what pin number they should be inserted in to.
Thank you ill give this a try, hopefully it works 🤞🏻
Iantt do you have any diagrams that has 2 black and white wires, ill send some pics of the wiring if you need them
