"Hill Start Assist not available" warning (occasionally)
Apologies for long post but I might as well give you all the info that I have now....
Over the last couple of months the "HSA not available" warning has been coming on occasionally, usually once I have come to a halt at a junction, not necessarily on a hill. It's getting more frequent.
I've owned the car for 7 years and it's only just started doing it. I suspect low battery voltage, although when I needed a new battery 3 years ago I never had the HSA warning appear.
Batt readings with a multimeter:-
when engine just turned off 12.08V
when engine off for 20 minutes 12.30V
Voltage across battery terminals when being charged by alternator 14.1 V (fluctuates 14.0 - 14.2) with all elect loads off, 14.0 V (fluctuates 13.9 - 14.1) with fan and headlights on.  I have never had to resort to charging the battery with a charger.
I would have thought these readings were OK but are they a sign of an imminent electrical problem?
Or is it just a sign of old age and I'll just live with it ??? (much like my own ailments!).
Any advice appreciated.
There is at least a 90% chance it's a simple case that the batteries health is failing. The voltage of 12.08V is very poor and even once the car has started to enter sleep mode a voltage of 12.30V is still only 70%
Your car uses a Smart charge system and as such charging voltages between 13.6V and 14.9V are quite normal and will constantly change.
Time to open the wallet and dig deep, looks like you need a new battery.
Thanks for the reply. I expect you're probably right about needing a new battery, although it is less than 2 and a half years old.
But why is my car giving me a warning (which stems from a low batt voltage, I understand) while the engine is running, because the voltage across the batt terminals is 14v.  How does it know that the sleep voltage is 12.3v? Or does it remember that and then say "when the car has been driven for 10 minutes, I'll tell the driver that there's a battery problem". Or is it just magic???
The 'Battery Monitor System' (BMS) monitors all current been drawn from the battery and all charge current flowing in to the battery. It knows the state of charge of the battery when it was parked and can easily calculate how much of the capacity has been used and what the present SOC is.
This is why on vehicles equipped with BMS that when charging the car battery you must charge it while the battery is still connected to the car. Also the battery charger positive lead has to be connected to the battery post, but the negative charging lead needs to be connected to the chassis earth point (NOT the battery). This then allows the BMS which is fitted to the negative battery post to monitor the charge and update the known value of the SOC.
That makes sense, thank you.
Try resetting the battery monitoring system:
1. Get in to the car and do all from points 2 to 4 within 10 seconds.
2. Turn on ignition with engine off (key in position II) . Turn on headlights.
3. Turn on and off 5 times rear fog light switch .
4. Turn on and off 3 times hazard light switch .
5. If everything goes OK battery light will flash 3 times on cluster within next 15 seconds.
6. Resetting BMS is now finished, so turn off ignition.
NOTE: To make fog lights work, you need to do this with headlights "on".
  • 2 months later...
Update.
The warning messages became more frequent (i.e. 9/10 journeys) and ALSO I kept getting "transmission limited function" virtually every journey, whereby I lost all the odd gears (which includes reverse!).
So I have replaced the battery (and reset the BMS) and there is no change at all. Any other ideas? Could it be a faulty BMS??? (I'd be happy to remove it completely, but I suspect my smart car would not even let me start it if I did that.
Have you read the DTC's using FORScan ?
It sounds like you have a problem with the TCM. It could just require to go through the reset and relearning programme but in all probability it is more likely to be a damaged wiring harness to the TCM.
Definitely get a scan done to check for errors messages. Forscan is the go to tool.
Funny reading this as my car has this also. I got my car scanned because of all things wheel alignment couldn't be done. Steering wheel position is shot. One sensor being out can trigger other warnings.
Therefore get a scan done.
Thanks both . I might have to bite the bullet and go down the Forscan route (though I fear with my IT skills that could be a rabbit hole that would take me days to negotiate and then escape from!).
TCM problem sounds quite likely, and maybe completely unrelated to the HSA not available message, which started happening first.
It's not a car I want to spend a lot of money on.
lol Alan. I tried to download Forscan yesterday. Got the 2 month free use activation code but blimey o'riley could I copy and paste it to the Forscan page! Absolutely not. Am flummoxed by it. Not as simple as I remember some years back. The disc I have with it on must be well out of date too as that wouldn't work.
Good luck.
