Fiesta mk7 side skirts
Does anyone know anything about fitting side skirts to non ST/ZS fiestas? I’ve just picked up a set off 5 door skirts but my car has none of the holes or clips
People generally just glue them on with Tigerseal or similar.
If you want them on correctly then use all the correct brackets/fixtures/end caps and use 3M tape to fix the thin ends in place, it's the fitting of the plastic connectors that scares me and the very reason I declined to buy any! There are about 14 which need to be fitted on the side of the sills, holes drilled and the connector pushed in, at a guess if you were buying the sills brand new from Ford you'd get template to aid fitting.
Has the skirts got the jack covers included ? Hope so as they are very expensive from Ford, a few years ago loads of them were getting nicked, then being listed on ebay, thieves making a killing.
Put this inquiry into the Fiesta section ?
Has the skirts got the jack covers included ? Hope so as they are very expensive from Ford, a few years ago loads of them were getting nicked, then being listed on eBay, thieves making a killing.
I do have all of the jacking covers luckily. I found a pack of 20 of the clips on Amazon, no template or anything and I don’t think I trust myself enough to play around with that. What do you mean by end caps? Mine didn’t come with any. I thought they would screw into the wheel arch without the need of anything else.
On the front sections there are black end caps, these things.....
https://www.ebay.co.uk/itm/393415914220?var=0&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338268676&toolid=10044&customid=Cj0KCQjwmtGjBhDhARIsAEqfDEf6RcAjdK29QOhD2V4fE3LJ6GULogWsWwkGxJAEDxJ-cpuz5B-Pn9waAv3_EALw_wcB
