Cluster
Hi my focus 1-8 2009 tcdi
the cluster randomly goes dark so I lose my indicator, all the gauges go black then it comes back and it’s ok for a while then it starts again, the fuses are all good, Any ideas? Thanks
It's possible that the plug in the back is loose.  The cluster is easy enough to remove with basic tools to check that.
However, there is a very common problem on these where the solder in the cluster cracks and causes poor connections which make and break during a drive.  I suspect that'll be the issue here, and unless you can solder, most people send them away for repair.
