S-max dtc's
My friend has a s-max and I did a scan on his car this is what came up
OBD-IIOBD-II
DTCs: 2
P1335(00) [0x133500]
Crankshaft Position Sensor Circuit Malfunction
EGR POSITION SENSOR A MINIMUM / MAXIMUM STOP PERFORMANCE
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle
P0069(00) [0x006900] Archive (inactive)
Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - correlation
Status: Test failed since last DTC clear
Engine control unitEngine control unit
DTCs: 2
ABS/ESP
No DTC found.
BCMBCM
DTCs: 176
B1108(77) [0x910877]
B1130(07) [0x913007] Archive (inactive)
U0200(00) [0xC20000]
Data bus, door function control module B - no communication
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
P0604(00) [0x060400]
Engine control module (ECM) - RAM error
Powertrain Control Module RAM Test Error
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
P0605(00) [0x060500]
Engine control module (ECM) - ROM error
Powertrain Control Module ROM Test Error
P062F(00) [0x062F00]
Engine control module (ECM), EEPROM error
P0801(11) [0x080111]
Reverse inhibit circuit - circuit malfunction
Reverse Inhibit Control Circuit Malfunction
P0801(15) [0x080115]
P1674(00) [0x167400]
CONTROL MODULE SOFTWARE CORRUPTED
C1108(12) [0x510812]
Status: Test not completed during this operation cycle
C111A(11) [0x511A11]
C111A(15) [0x511A15]
C111B(11) [0x511B11]
C111B(15) [0x511B15]
C1120(11) [0x512011]
C1120(15) [0x512015]
C1A41(21) [0x5A4121]
C1A41(22) [0x5A4122]
C1A56(16) [0x5A5616]
C1A56(86) [0x5A5686]
C1A56(93) [0x5A5693]
C1A57(11) [0x5A5711]
C1A57(12) [0x5A5712]
C1A57(13) [0x5A5713]
C1A58(16) [0x5A5816]
C1A58(86) [0x5A5886]
C1A58(93) [0x5A5893]
C1A59(11) [0x5A5911]
C1A59(12) [0x5A5912]
C1A59(13) [0x5A5913]
C1A60(16) [0x5A6016]
C1A60(86) [0x5A6086]
C1A60(93) [0x5A6093]
C1A61(11) [0x5A6111]
C1A61(12) [0x5A6112]
C1A61(13) [0x5A6113]
C1A62(16) [0x5A6216]
C1A62(86) [0x5A6286]
C1A62(93) [0x5A6293]
C1A63(11) [0x5A6311]
C1A63(12) [0x5A6312]
C1A63(13) [0x5A6313]
C1D18(00) [0x5D1800]
C1D21(05) [0x5D2105]
B1092(11) [0x909211]
B1092(15) [0x909215]
B1095(12) [0x909512]
B1095(14) [0x909514]
B1096(12) [0x909612]
B1096(14) [0x909614]
B1097(12) [0x909712]
B1098(11) [0x909811]
B1098(13) [0x909813]
B1099(11) [0x909911]
B1099(13) [0x909913]
B109B(11) [0x909B11]
B109B(15) [0x909B15]
B10A5(12) [0x90A512]
B10A5(14) [0x90A514]
Is this car knackered or does it just have major water damage to electrics?
