Ford focus nexbase
I have a new focus hybrid and I seem to have a problem that the nexbase canot stop charging from the fuse box.... does anyone recombend which fuse box should be used?   I've had to stop using my nexbase 522 as it's wiping out my battery
I'm not familiar with the Ford Docus Hybrid, but assuming it uses the same fuse box as a Focus then connect the dashcam to fuse 3.
PS. You might like to amend your profile 😉
  • 4 weeks later...
Is Fuse No3 a permanent 12v feed or only live with ignition? I'm asking as I intend to fit my nextbase dashcam to my focus.
Well provided that you have the exact same fuesbox as the one posted above, Fuse 3 is live only when the ignition is on.
Now is that advice just for the Focus, or does it also apply to the Ford Docus as well? 🤣
