Help identifying components Ford Kuga 1.5 Tdci 2018 Titanium
Hello, Can somebody tell me what components are located between the front nearside wheel arch and front nearside headlight, i.e., what components are hidden between the wheel arch and front of the car? Thank you.
The PCM (Engine ECU) is located in that area.
Thank you for your replies. Now I know what to look for I can see about replacing damaged mountings, to both the PCM/ECU and what looks like an in-line lighting control module, both spotted loose as I was changing the oil from below and [damaged] air filter lower housing from above.
