MAF flow rate
Can anyone advise me what the MAF flow rate should be on a fiesta 1.0 ecoboost 125hp.
thank you
It varies with the engine RPM
At idle it’s around 1.5 g/s and today when driving it went up to around 8.5 g/s. Not sure what the RPM was at that point though. A topic online stated that at idle your typical vehicle should be between 2 -7 g/s and when driving typically 15-25 g/s. Was just wondering if my MAF sensor is goosed.
it's far more likely that you have an air leak after the MAF sensor and the engine is able to draw un-metered air which is why your MAF readings are low.
