Question focus mk2 2006
Hi I have a question.
I have a focus mk2 2006
And I wanna change the steering wheel.
Is it possible to put a 2019 wheel on there?
Thank for the help
Physically, yes.
Electronically, not without considerable modification.
The two models use totally different communication systems. In simple terms the older model is analog and the 2019 model is digital.
On the subject of swapping steering wheels from different models here is an old thread
On 6/7/2022 at 11:53 AM, JW1982 said:
The MK2/MK2.5 steering wheel control buttons are connected to a conventional clock spring. The steering wheel control is an analog resistance circuit that is directly connected to the instrument cluster.
The MK3/MK3.5 steering wheel control buttons are connected to the Steering Collumn Control Module (which is integrated into the clock spring). The SCCM communicates digitally by CANbus communication.
To make it work you need to modify the circuit board of the MK3.5 to match the circuit and resistance values of the MK2.5. This requires advanced soldering skills. A lot more info about this subject can be found on the Russian Ford forum.
