brake lights stuck on!!! fiesta 2002 1.4 zetec
another driver informed me my brake lights were stuck on.
on investigation, it is only when the ignition is on , all 3 lights are on including the middle high one.
handbrake seems ok as the dash light goes on and off ok when i operate it.
any ideas what it could be, and is there any more checks i can do to narrow it down??
Brake pedal switch.
cheers tom is this an easy replacement?
Is this a 2002 Fiesta ? Your profile says it's a 2009
Only a twenty minute job, just unclip the switch remove the plug and reverse the procedure with the new switch.
10 hours ago, TomsFocus said:
Brake pedal switch.
It could simply be that it has got knocked off it's position and needs reseating, if not, new switch
its  2002 the 2009 got written off. on gsf they have a few parts reg is RJ02XVG some have cruise control ?? the cheap one not in stock.. guess ill go there and ask.
i had a look and both sensors were not attached! so i attached the one i think is for the brake lights and twisted it but a bit of plastic broke off, which holds it in place.
so i defo need a new switch and a small flat screwdriver to replace it.
gsf quoting £35 , bit high isnt it ? i wonder if theres a way of cable tying it in place?
Which switch do you need?  It should be the lower one that controls brake lights.  (Easily tested)
Can be had for around £15 on eBay.
Genuine dealership for £40 - Genuine Ford Brake Light Switch 1088170 | eBay
Or genuine from private seller for £25 - Genuine Ford Brake Light Switch 1088170 | eBay
the one in there works because i tested it when its held in place , its just the plastic tab has broken which  secures it when you twist in in place.
sorted.... secured it back in place with a couple of cable ties...its not going anywhere!!! thanks for all the help
haha cheers tom !!
