Squeaking noise
Hello All,
I have recently discovered I squeaking noise on the passenger side of my 2018 Ford Fiesta. This only occurs when idling or when below 1 1/2 thousand rpm, and sometimes it is worse than others, and it also occurs when the air-conditioning is put on.
Any ideas what this is?
Hello Harry. Is the squeaking noise there when the aircon is off? I assume once revs are above 1.5k the squeak stops.
Check the condition of the belts you can see under the bonnet. Sounds like a lose belt.
