Mondeo sync3 updates
Hi guys what's the best way to update the sync3 system. I've seen that it can take up to an hour to update with the car running any suggestions are gratefully appreciated
If you are using the updates from the Ford website then you can either go for a long drive while it is updating, connect a battery charger on the drive with the ignition on but engine off - the system will still shut down after a while but you just go out and turn it on again, or just leave the USB stick in and act normally as I believe the system will continue from where it left off whenever you stop and start again.
Thanks for the information 👍
