Er0701 on 2013 1.6 diesel fiesta
Hi hope somebody can help please Er0701 came up when the car was started from cold and it's in low power mode but everything seems to working correctly and there are no other codes. But the error will not clear so must still be active but what? This is a manual transmission car so baffled.....
Very much depends on what code reader you are using. Generic code readers very often don't or can't read all of the Ford specific DTC's.
Use FORScan and a vLinker FS cable to be sure to get all of the Ford codes and be able to clear fault DTC's.
FORScan: https://forscan.org/download.html
vLinker FS cable: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
Just now, motormech said:
Thanks unofix, I am reading Er code from dashboard so sounds like i will need to get a garage to read codes for more info.
