Fuel gauge
My 2009 1.4 fiesta shows the fuel low warning light on, came on at 50 miles but needle shows 1/4 of a tank, is it the fuel pump with sender required? Can you get the sender separately? Tia
On 11/30/2023 at 7:13 PM, kelland said:
Hello there !
Try to disconnect the battery, wait 5 minutes, and reconnect it.
If it still doesn't work, try to fuel up your tank and see if the light goes off and if it appears again at the same remaining fuel amount.
Ditto to the last post.
If you remove the battery and reconnect it tends to throw the reading out.
I normally have to wait till my tank catches up with my car or fill tank to the top
