Ford fiesta heated windscreen
I have a Ford Fiesta 2013 1.5 Diesel, I seem to be having an intermittent issue with my heated wind screen, it doesn't work a lot of the time, however when it's does turn on it works perfectly fine.
I had battery changed as it was getting old however wasn't seeing an improvement, and as it does work sometimes not sure if it would be a fuse, any ideas on what this could be?
A fuse either works or it doesn't.
Have you checked your battery voltage? Make sure your alternator is charging the battery properly.
A new battery will only buy you a bit of time if it's not being charged correctly.
Check the connection tabs on the side of the screen for corrosion.
