09 Fiesta Air Con Problems
Hi all.
I have an 09 fiesta and there is a problem with my air con. It will work for about 2 mins once getting into the car then slowly cuts out. Halfords says it’s a leak but I’m trying to find the cause as this has only started happening since I hit a bad pothole the other night. This pothole has already been responsible for a cracked wheel rim on my vehicle so I’m wondering if it may have anything to do with the air con problems, or if it’s just a coincidence.
Thanks.
They are most likely correct.
You need the system filled with a UV dye so that the leak can be found.
