Part name?
Hi, anyone know the proper name for this part please?
This is on a ST but the hole in the side panel in my boot looks this shape
It's likely to be called a grill, vent or louvre.  I can't find any available separately from the carpet panel though.
Could it be this part ?  From CatCar
Panel Assy - Side Trim  1862450
Not sure, here is the part that I bought which doesnt fit
Open photo
And here is the space in which it needs to fit
https://www.catcar.info/ford/?lang=en
This is the website from which I found that number using the exploded view - do you have a part number for what you bought ?
Yes, it's here
Thanks btw
Unfortunately, Catcar only gives the FINIS codes, which I cannot cross reference with any thing on that label.
Panel Assy - Side Trim ford on ebay gives a couple of hits - but for a Transit
I can only suggest that you have a look round a scrappy, if a Ford dealer cannot help you.
Good Luck.
Catcar doesn't cover Mk8 unfortunately.  You would need a Ford employee to check the proper catalogue to see if it's available to order separately brand new.
Gala do have a full panel in stock, could ask if they'd split...
https://www.ebay.co.uk/itm/254782426704?
Cavalry to the rescue !
