Switching manufacturers fittings between cars
I have a 2008 1.4 titanium is it possible to transfer fittings like cruise control and an auto dim rear view mirror in to something like a 1.6 st of the same model range, if so what needs to happen?
It can be done but to make them work you have to use a program called 'Forscan' this connects to your cars brain, then you 'enable' what gadgets you work to fire up and work correctly.
Probably not between generations.
MK2 to MK3 Focus rain sensor won't work and MK3 to Mk3.5 doesn't either
Thank for the advice, also is it possible to get it re-badged / titled by ford? Since taking all the bits that make it a titanium and still call it a titanium seems a bit misleading, and insurance will still call it a mod and destroy you on cost. (Same for the other car)
No. It will always be what it was the day Ford built it no matter what changes you make.
So tempted🤣🤣🤣🤣🤣🤣
1 minute ago, iantt said:
So tempted🤣🤣🤣🤣🤣🤣
The Profanity Filter wouldn't let you 🤣
Unfortunate, thanks for the advice
Hi.
If you have any issues with insurance at all then please feel free to drop me a line.
Regards,
Dan.
