Exhaust Steaming.
Since the weather has turned wet and cold I'm noticing quite a lot of thin white smoke coming from my exhaust, almost like vapour as I've been told which it is due to weather conditions. I haven't had my ST long so I'm unsure if it's common for them to be so "steamy". Coolant has been same level since I bought it and the exhaust just smells like a steamy boiled kettle when it does this. I'll also add its only noticeable during the night if light is shining on the exhaust.
Normal. Burning petrol produces water vapour. Alot more than most people think. Can't remember what the ratio is but , for 1 litre of petrol burned in an engine the resulting water vapour is around 1litre if you caught it out of exhaust. Something like that.
As above, normal. My old ST24 (2.5 V6) was very steamy. Even my current 2.2 diesel is too.
Will it tend to do it whilst idling as well even if the engine is warm because of the weather 😅?
My 1.5 ecoboost does. Steams lovely even when the engine temperature needle is at normal.
Yes, all that water vapour from burning the fuel has to go out of the exhaust, and, in the cold, it will condense making it more visible.
