Focus 2011 mk2 titanium no ignition
Hi
I am hoping I have posted in the right section as I am new to this forum.I have got a non start with my keyless focus titanium . Every time I press the start button I don’t get any ignition. I get radio and the menu in the centre of the dash .The battery is fine as it measures over 12v .
If I disconnect the main power plug on the gem on the passenger side and reconnect the ignition comes on and I can start the vehicle with no problem and runs fine until I turn it off and problem starts again. I suspect the gem module it self ? Just wondering if any of you clever people have had this sort of problem before. Thanks
Water ingress to the GEM is a common problem. You need to fully remove it and carefully check for signs of water, and/or greenish corrosion of the circuit board.
Hello, next week I decided to go on vacation with my family and I changed the car's battery so as not to have problems with it. Unfortunately, after changing it, the car radio asks me for an unlocking code and I don't have it.... I looked on the internet for a solution to solve this problem and I found this tool to give me the radio code, what do you think? you have??
Fitted a brand new second hand GEM🤣 and programmed using ELM config and pleased to say that it is up and running. Many thanks
