HELP!!
Can anyone help!
ford focus 2015 diesel 1.5
car will randomly cut out while driving with engine service now message
if I restart it will idle for around 10 seconds then die again. If I leave the car for 3-10 mins it will start again and drive fine until it happens again ( intermittently)
had it plugged into scanner and getting all sorts of faults (have pictures / videos)
Desperately need some advice
If you are using a generic code reader (even the super expensive type) then it will not be getting the Ford specific DTC's which are probably of importance with a problem like yours.
Use FORScan and the vLinker lead to get all of the codes.
What DTC's have you got at the moment ?
