Galaxy
Hi I have 2017 galaxy heated front screen not working fuse are OK
On 12/6/2023 at 3:34 PM, unofix said:
Did you check both fuses ? There is one for the left and one for the right.
You need to access the connections on the screen for the drivers side and see if you have any supply. Remember the front heated screen only works when the battery state of charge is good, the outside temperature is 7oC or less and the engine is running.
Has the windscreen been replaced at some point in the past ? It could well be that one of the push-on connectors for that side of the screen has become disconnected.
Check the SOC of your battery.
Never bin replace heated wing mirrors are on
That was with regards to the other thread. The highlighted text was the important points.
Heated door mirrors are on the heated REAR screen circuit and have nothing to do with the front screen.
