Puma engine
I have just bought a Puma one litre eco boost and I am hearing bad reports about engine problems.
It is a 2021 plate I have purchased extended warranty with the dealer Evens Halsway for an extra 3years
should I be worried 😔
Cams are run on a chain on this engine, just the oil pump uses the wet belt now.
Still always use the correct oil and never use flush
should I be worried
Sounds like a scam, never heard of that dealer 🤣
There is now a lot of misinformation out there about this. The engine you will have heard about has a "wet" cambelt which can be problematic. This engine has never been fitted to the current Puma which has a revised engine with chain cam drive.
