Arb Tie Links
i replaced the arb tie bar links on my 2000 focus less than 10,000 miles ago ...it now sounds like they need replacing already...does this signify another fault do you think?
Did you use an anti seize compound like copper grease? It could be another suspension item such as the sway bar bushings. There easily visible once the car is jacked up to see if they have perished.
thanksfor the prompt reply and no i didn't use any grease didn't know you had to,where do you apply it ?
