Transmission error message on start up
Have a cmax with power train box
get message on start up ( on cold days) transmission limited function.
turn off engine and reset tcm and no problems car goes like a dream.
have diagnostically checked and no faults with gearbox or tcm
any ideas ?
is this a common fault and what’s the solution
Poor battery voltage or poor earth to body from battery or transmission
Battery was replaced in 2022
car is not used too frequently loke maybe once a week or so
Then there is a very good chance the battery State Of Charge is low and it needs charging up.
Fully charge the battery first, then check earths
If you're going to disconnect the battery to charge then clean and re-grease the earths whilst it's disconnected (it's recommended anyway)
Remove the earth eyelet, clean the paint away to bare metal in the area where the eyelet sits, grease metal and refit eyelet
The transmission ones are underneath the air box base on the chassis rail
