Ford focus 2014 airbag light illuminated ?
My Ford focus titanium x has just illuminated the airbag light. Car sits in the garage on a trickle charge so not to drain the battery as it’s not driven much but is started once a month. I've tried moving wires under the seats. But the light stays on. Is there a common fault I could look at to resolve this issue.
You have to disconnect and reconnect the multi plugs under the seats a few times, to clean the contact, with the battery off
If that doesn't cure it you have a restraints system fault elsewhere and need to read the codes
Thank you. I will try doing the plugs again as mentioned.
If that doesn't work then you need to use FORScan and read the Ford specific DTC's
