Space saver wheel for a mk8 fiesta 2020
Hi just Got a 15 in skiny space saver wheel  is this safe to use on the rear of 16 inch alloy wheel replacement for ford fiesta trend . The difference from top to bottom  of the  tyre is about  2 inches would this be safe to use in emergency short term at please ?20240226_170826.thumb.jpg.a68c830470f962fb667d80193cda04de.jpg20240226_170826.thumb.jpg.a68c830470f962fb667d80193cda04de.jpg20240226_170908.thumb.jpg.05f6f5787b0e6f93df9009833aed85c6.jpg20240226_170908.thumb.jpg.05f6f5787b0e6f93df9009833aed85c6.jpg20240226_170826.thumb.jpg.a68c830470f962fb667d80193cda04de.jpg20240226_170908.thumb.jpg.05f6f5787b0e6f93df9009833aed85c6.jpg
Yes it will be fine. That is the normal size spare for a Fiesta.
Thanks a lot for your  reply . Even though the hight of the space saver tyre is about 1 inch or so  each side less on the wall  hight . You think will be OK  ?
Many  thanks again for all your help on this subject .
Andrew
At the risk of repeating, it is the only space saver spare for use on all Fiesta's regardless of the normal wheel. The only exception is the Fiesta ST which has much larger front brake calipers and so uses a special spare.
Some users like to always use the space saver on the rear wheel and if needs be move a full size wheel to the front.
Thanks again many Thanks for all your help again 🙏 👍
